Case GT mower decks.
CKain(MI)
Anyone know if Case provided a, righthand discharge, mower deck, for the 200 & 400 series tractors.
Thanks
Ok, I thought maybe the belt was routed to the deck drive pulley different, to reverse rotato direction.?
The newer ingersoll have right hand discharge ,
The newer deck rotates the opposite direction due to motors
The motor installed 180 degree .
So the older left hand decks work with the belt clutch
Mounted on flywheel end . Which faced the front of the tractor. And the newer ones work off the
PTO end of the engine. Which now faces the front of the tractor , which rotates in the opposite direction , same goes for snowblowers
