kohler K301S
buzzinduzzin
Location
se illinois
hello , been on yt several years but first time on this section. looking for a breakerless ign. module & voltage regulator.( me & 100 other people !! ) if not available how much trouble is it to convert to a points ign. sys. ? any generic voltage regulators ?
K301S 47371C TIA !
You need an ignition switch, coil and bracket, points and cover and two screws and a push rod. Knock out the push rod plug in the block. Probably missed something but that will get you started.
Ive never worked on a Kohler K301 that
DIDN'T have points. I have worked on the
MAGNUM series single cylinder cast iron
engines in equal HP to the K series that
had a magneto style of electronic ignition.
Is that what you mean?
(quoted from post at 16:32:10 11/06/21) Ive never worked on a Kohler K301 that
Hi Don check the Kohler manuals they indeed did come out with a breakerless ignition system in about 1968 on engines with the 15 amp alternator system but they dropped the system sometime in the 70's and went back to the battery/points system, the breakerless system is covered in SB 55 and the conversion to battery ignition is covered with Kit 237750-S
(quoted from post at 11:18:24 11/06/21) hello , been on yt several years but first time on this section. looking for a breakerless ign. module & voltage regulator.( me & 100 other people !! ) if not available how much trouble is it to convert to a points ign. sys. ? any generic voltage regulators ?
K301S 47371C TIA !
I have a K301 in my Case 222 that has a starter generator. I went through a couple of Voltage Regulators but the new ones seem to be of poor quality. I posted on YT for some ideas and one reply sent a picture of a successful hookup using a motorcycle VR. The particular unit is model # 74504-78 and is available on amazon. I got one and hooked it up and it works just super because it is solid state. Here is the pic sent by Doug-Iowa :
Hey thats pretty cool! Will that work with any Delano S/G? I have IH Cub Cadets and the VRs from India or wherever suck. Where does the red wire go?
[/quote]
This is interesting that's my engine and I've posted the information on using that Solid stat regulator a number of times I'm glad some have installed it and its working I have two engines equipped with that regulator both work excellent
GB in MN
(quoted from post at 23:48:59 11/09/21) I have a K301 in my Case 222 that has a starter generator. I went through a couple of Voltage Regulators but the new ones seem to be of poor quality. I posted on YT for some ideas and one reply sent a picture of a successful hookup using a motorcycle VR. The particular unit is model # 74504-78 and is available on amazon. I got one and hooked it up and it works just super because it is solid state. Here is the pic sent by Doug-Iowa :
GB in MN[/quote]ttps://forumphotos.yesterdaystractors.com/photos/mvphoto84304.jpg[/img]
This is my Case 222 with the VR 74504-78
Thanks for sharing Doug's picture and idea for freeing up a stuck clutch that's one to remember
GB in MN
No apology needed I post the information hoping it would be another alternative and I'm glad its being used
GB in MN
There are a lot of home-brew replacement ignition systems for Tecumseh
engines, primarily the HH100. The Tecumseh unit is NLA anywhere.
Most recent versions use a Ford F150 antilock brake sensor and a
GM HEI unit.
It shouldn't be that difficult to adapt the concept to a Kohler engine.
(quoted from post at 04:35:00 11/14/21) There are a lot of home-brew replacement ignition systems for Tecumseh
GM HEI unit.
Why mess around with some home brew that may or may not last converting the K301s to battery/point ignition is simple and will last of ever, as for the Tecumseh's with SSI there is an aftermarket plug and play ignition unit designed for them and it will last forever
GB in MN
