Case RM48 deck
CKain(MI)
Anyone use a right hand discharge Case deck. I can get one in a trade. My Agri-Fab leaf vac is made for the righthand stye.
Any issues known ?? I have two Case GT's with left-hand discharge.. Thanks
I know you can use a hydraulic-drive right hand deck on a 3-digit if it is equipped with a hydraulic PTO valve. Regarding the belt-driven mower decks, a 3-digit tractor (i.e. 446) runs a left hand deck, while a 4-digit tractor (i.e. 4016) runs a right hand deck. I don't know if a right hand will work on a 3-digit tractor. I have foggy memories about the 4-digits having the Onan P engine mounted opposite to the 3-digits Onan B which changes pto belt direction. I have experience with a 446 and an all-hydraulic 4118. Never had a 4-digit belt drive. Something to look into before you make the deal.
The deck was on a 80's 444, belt driven. I have a 80's
444. should work, I want the model number to order blades and belts..
