Snow blade for X300
I have an X300 and I am thinking about getting a snow blade for it. If I get a used blade are they fairly universal as far as fit? Or do I need to get one specific blade for a X300. Will I also need chains and weights? Thanks for any and all help.
I tried a blade on a 200 series tractor, but couldn't do much. You need front and rear weight plus chains. The blade on mine was lever controlled, floating was always a problem as it just skidded over stuff and angling the blade just shoved the front end where ever.
It could only work on smooth hard surface and then you are traction limited. I hope you end up with a better arrangement than what I had. Still have tire chain scratch marks in the concrete. Leo
