DMartin9N-2N
Good afternoon all: I have got my variator and steering gear in good order, now I want to grease the chassis. I know about the fitting under the right pedal shaft, also at the king pins, also the idler pulley bracket under right side of engine. BUT, where is the fitting for the front axle where it pivots on the tractor frame? It has been a long time for me, and can't find my book, either! I suspect I need to remove the "draft plate" or arm that connects the front of mower deck to front of frame. I probably should have greased that fitting before I put the mower deck back on....
Any help from someone who has been there, done that; much appreciated.
Dennis M. in W. Tenn.
