FiremanJohn
I am rewiring a John Deere 316 with the Kohler motor. You should have to take a test to earn crimping pliers but that is another story. Everything is perfect except I have one question. The key switch I got does not have the fifth terminal for the wire from the regulator. Without the reg terminal can I use this switch, and which terminal do I hook the wire to? It is a plug on the motor and two wires go to the stator so I assume it is that third wire I hook up. My early guess is I go to the acc. Terminal. But I am not too familiar with these systems and dont want to fry anything. Thank you in advance.
