Tim in New York
One of the oils seals on my Troy-Bilt tiller is leaking badly. Its on the tine shaft, not the drive wheel axle. I got the tine shield off, and I have no idea how to take anything else apart to replace the seal. I am guessing I need to get under the cover of the gear box and remove the shaft? Or does the seal somehow press fit from the outside if I take off all the tines? Never done any seal replacements before.
Its a Super Bronco if that helps. I do have the seal and the gearbox gasket on order.
Thanks,
Tim
Thanks,
Tim
