whizkidkyus
- Location
- South Central , Ky.
I have an old Briggs engine on a push mower . Its approximately a 1989 model ! Its old enough that it doesnt have a primer button but a choke instead ! Old enough to have the little cover on the side of carb with the one bolt that the metal rod from the diagram to choke and the gas adjustment screw on carb that you have to get to thru the little hole on the back bracket ! It even has a throttle cable . Ive cleaned the carb and replaced the diagram along with a new air filter , spark plug and had it running good ! Now it just wants to start and run a few seconds and die ! My question is - how many turns should the gas screw be back out of carb or set on ?
Thanks ,
Whizkid
