700 hour 40R577 BS V twin riding mower used without the deck as a Gator get around vehicle. Has the aluminum intake manifold. Recently started having intermittent loss of the right cylinder.
Compression 145 both sides, new premium fuel, filter, does it with the air cleaner off, I keep the oil clean, was running Iridium plugs and have changed back to the Champion Y12s and NGK 7938 V Power, all 3 would dry carbon up, grey insulator on a new plug while the good side was pure white.
Its totally random in too rich a mixture on the right bank and causing the plugs to foul with dry soot. Seems to be real sensitive to choke now as compared to normal when I push the lever over to full choke. It'll run normal for a time, maybe as long as 10-15 minutes and then start limping on one cyl. Just when you think your chemical treatments of fuel and through the air intake have done something, it does it again. Pushing against the governor on the throttle lever and it has no problem revving to way over 3600. Checked intake manifold and all suction hoses and no loose fittings, cracked hoses or any clues. Being overly rich one wouldn't expect an air leak anyway......that would lean out the mixture.....
I can't determine if I am chasing fuel or spark, or maybe a sticking intake valve stem....but the pattern doesn't seem like a stem sticking, besides with honey colored syn. oil in it all the time how would it get gummed up in the first place.. I checked the gap on the mags and put a timing light on both plugs. When it bogs I don't see any difference in the light patterns as when it's running ok. I am tending towards fuel due to the over rich condition causing the sooted plugs (opinion). I guess I need to remove the intake assembly and go through the carb (I did remove the shut off switch and drain the carb and what came out was clear with no sign of debris...it has lived on E10). If it were float/needle valve related, the intermittent nature of the problem doesn't support something that I think would be a constant menace if applicable. Its haying season and I don't want to tear it all apart just now.
Thoughts appreciated.
