Part Numbers
Garryllk
Hi again
I was wondering if you would have the part number for the breather hoses that go from the breather to the air cleaner ?
Also if you would have the gasket part number for the intake manifold where it bolts to the engine
Seems I don't have the right numbers either
Thank You
Garry
Thank you All the numbers are there.
I will need the breather for cyl # 2 also after taking off the hose its not any good from what I can tell.Its exactly the same size as cyl 1 breather but taller on the top of the plate it screwws to which doesn't natter as a fit for it but I did see some on amazon that looks just like what I need Wondering if Hemilton could possibly see if he has one
I will need the breather for cyl # 2 also after taking off the hose its not any good from what I can tell.Its exactly the same size as cyl 1 breather but taller on the top of the plate it screwws to which doesn't natter as a fit for it but I did see some on amazon that looks just like what I need Wondering if Hamilton could possibly see if he has one
Hi
That would be great
The 12.5 brigs is a 2 cyl engine on a lt12502 Snapper garden tractor(Engine number is 404437-0113-01)
Part number I need is cyl 2 breather number is 495756
Also both tubes from the breather to the air cleaner S shape number 280185
Thank you I hope you have at least the breather
garry
