This is a Yardman that was given to me years ago. It has sat for a number of years not running. It has a Tecumser Products CO. engine on it LEV115 35016E. Took the carb off and cleaned it up. Pull cord will not retract so I have rigged up a way to spin it over with a 1/2 inch drill. Took a 1/4 inch bolt and ground the head down to fit a 3/8 drive socket. It hits once in a while but will not run. Has a good spark that will jump well over a 1/ inch gap. Carb linkage was a bit hard to figure out how to put it back on. Linkage fell off while taking the carb off. Guess I'll be messing with the carb some more.
Any ideas what might be the problem??
Thanks
Thanks
