Kubota B8200 mini Tractor.
JL Ray
I just got this tractor with a manual, however I can not figure out how to start or stop the PTO. The manual shows a lever just behind my left leg as I sit in the seat. It is labeled PTO speed gear. This is the only thing that is labeled in the manual and on the tractor that indicates anything to do with PTO. I have tried moving it but it has a block plate holding it in one speed. Is the same lever suppose to move side ways to turn the PTO on or off and its just stuck?
The lever only moves fwd/back. The middle position is neutral. the plate restricts it to neutral and 540 or neutral, 540 and 748 depending on which direction it is installed. The plate can be unbolted and turned over. I think with the tab fwd is where all speeds are available.
