Ingersol start stop up date
Replaced key 4 pin key switch with new 5 pin switch all starts and stops correctly. Replaced old hydraulic fluid what ever it was with new Hydraulic specific fluid all operates correctly [traction motor and lift cylinder ] quite pleased with how the tractor 224 Ingersol [case] works.
Glad you got it going!
If you encounter a loss of pressure/drive power when the fluid is hot, consider changing to engine oil. 20w40 engine oil was the factory recommendation, that is hard to find today. Most use a 15w40 or 20w50 oil.
