1946 BN IHC
would like direction and assistance
Working on an Ingersoll 224 lawn tractor with 14 hp., Kolar; since wiring was no good; totally rewired with new wire 12 G. >> Engine starts and runs >>> yet when I shut off key switch engine keeps running. To stop engine have to pull high tension wire off plug. As far as I understand I have connected all wires to proper places. Gone over the wiring schematic several times, even enlarged it to be as certain as I can of placing of wires. [ there is one item that I see on the diagram line from the 4th., post under the voltage relay to the battery terminal of the solenoid > looks like a fuse holder or connector yet might be a one way diode << cant tell from diagram]
Could anyone who has further information on these lawn tractors give me guidance? So that when I turn the key to the of position the engine will shut off.
Thank you.
Wm.
Thank you.
Wm.
