Holes wobbled out in the end of the shaft next to tranny, and I bet the shaft is worn where the throw out bearing slides, teaser spring, etc.
what type of shaft material should I use: cold rolled, hot rolled, shaft stock from a hardware store, big box, TSC?
Educate me here.
Also, the stub shaft sticking out from the transmission, and the coupling, have wallowed out holes. How might I repair these? (Weld shut, redrill? )
Will any of that Liquid metal, epoxy stuff, work?
Educate me here.
