Depending on weather it's the width or the thickness of flat bar on cultivator you may have to use a drill mounted grinding wheel/sanding disc to remove material a little at a time on width/thickness of flat plate on cultivator hitch,the slot hitch being made of cast iron is not all that square inside the slot,usually has hi/low spots in same,I have slot hitch and flat bar trailer hitch on 3 of my 4 tractors.
About 10 yrs ago I bought an old Magna America front tine tiller(agway brand) with a 3hp eng at an estate sale,went to red square and went thru manuals library(much small then)and found owners manual/parts list for a self powered tow behind front tine tiller that wheel horse sold for their 4-7hp tractors in the mid 60's,these tractors also used a slot hitch for raiseing/lowering tiller in operation,made up extended axle assembly for wheels and a flat bar hitch similar to hitch on your cultivator,the REAL problem was when I moved tiller from one tractor to another I had to touch up flat bar on hitch so it would slide into slot due to casting hi/low spots inside slot hitch
