Garden Tractors Discussion Forum |
John Deere LX255 charging light on
Author |
[Modern View] |
daisyman
12-15-2020 11:55:21
Anyone have a light on the charging system that they can't get to shut off? Background: 2000 JD LX255, Kohler CV15S-41571. Good battery. Checked and cleaned posts. Checked and cleaned terminals on voltage regulator and wire connector. With the engine running, 14.4 volts with a good digital meter. Swapped regulators, 13.46 volts. Put original regulator back on, 14.4 volts. Voltage with tractor off, 12.46 volts. It appears the charging system is working, but the light stays on. I cleaned all the wire connectors I could find and applied dielectric grease on all of them. I just got this tractor a couple weeks ago, so I don't know the history of it. John Deere service ADVISOR makes no mention of the light, that we could find. A check of the stator output voltage at idle is supposed to be 26 volts AC, and that checks out OK. Any ideas? I've about run out. (I've got to go to the dentist, so I won't answer for a while) Thanks, Irv
wore out
12-21-2020 16:22:27
Re: John Deere LX255 charging light on in reply to daisyman, 12-15-2020 11:55:21
Thanks for posting back!
daisyman
12-18-2020 16:30:23
Thanks to all for your help! I knew someone on here would know. I've got that module ordered from my JD dealer, they were out. Should be here Monday afternoon. I'll let you know how it turns out. Irv (I think I answered this once and it didn't show up, so if it comes up twice, you'll know why)
daisyman
12-18-2020 16:08:46
Thanks to all of you for your help. I've got that discharge module on order from my JD dealer and it should be here Monday afternoon. I'll let you know how it works out. It's a great day, I learned something new! Irv
wore out
12-17-2020 22:03:01
Looks like "tirekicker" has it. I withdraw my comments!
tirekicker
12-17-2020 17:50:34
discharge module, john deere AM126691
daisyman
12-21-2020 13:07:19
Re: John Deere LX255 charging light on in reply to tirekicker, 12-17-2020 17:50:34
Tirekicker, you were right on the money with that module. I just got it and put it on and out went the light! Thank you very much for the information. Merry Christmas to all of you! I'm a happy guy! Irv
t.r.k.
12-17-2020 08:52:41
Back when I was running my 318 I ignored the light. I am thinking your problem is either in the black box in the dash (if its like a 318) or the ground wire to it. If you are getting over 12.6v at the battery it is charging. Since you have confirmed that it is charging don't worry about it.
wore out
12-17-2020 10:11:07
Re: John Deere LX255 charging light on in reply to t.r.k., 12-17-2020 08:52:41
I concur. The LX255 charging indicator light is control by a section of the Time Delay Module, and had nothing to do with the actual charging system. If no loose grounds or other poor connections in that area likely the module has failed.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Single front wheel assembly for 18-27 hart par
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
