A block question.
gregww
Below is a pic of the Tecumseh block for my Wheel Horse 656. It shows one of the bosses for the starter mount is broke. I have considered my options. Leaving it as is, hope for the best, or drill completely through the block, tap the hole, and put a good sealer on the bolt. The location is high in the sump. Any other ideas? What would you do? There are 3 other bolts for the starter.
Are you able to drill and tap another (maybe smaller) hole inboard of that one
both on the starter and the block?
(quoted from post at 04:18:51 12/05/20) Are you able to drill and tap another (maybe smaller) hole inboard of that one
hen I first read this, I thought it was an excellent idea. Then I looked at the starter. It has "ears" on it in specific locations. I would have to weld to the starter housing to add more ear. Don't think I want to do that.
Looks like there is a bit of hole left at
the botton? Using a bottoming tap and try
to get a thread or two. Then obtain or
make a stud from a soft bolt so it can be
drilled. Wash to hole and stud thoroughly
with brake cleaner. Apply a bit of JB
weld to the stud and screw it in. When it
is hard drill a small hole , maybe 1/16"
sideways the stud and into the block for
a roll pin. Drive it on and smear a bit
more JB over the repair. Be careful about
tightening the nut.
(quoted from post at 07:18:48 12/05/20) Looks like there is a bit of hole left at
tightening the nut.
hat sounds like a plan. Think I will try that. Thanks all. Greg
By jumpin-gee-hoss afat. I think it just might work. The stud is screwed in finger tight. There is a 1/16" hole drilled through the stud, and into the casting. A roll pin is driven through the stud and into the casting about 3/8". The pin protrudes from the stud about 1/16". EVERYTHING was was cleaned and then coated with JB weld, then assembled. I scuffed the area with sandpaper to give the JB Weld a little more bite. If it does not work, It will not be for lack of trying.
