Giant vac. 5hp briggs
ffinmich
I have a giant vac. Leaf blower.it has a 5hp Briggs magnetron engine. It runs good for about 1/2 hour then stops.seems like it might be getting hot. Don't know much about it since it was given to me.any ideas?. Thanks.
(quoted from post at 10:31:27 11/11/20) Thanks for the response
Any way to check the ignition or valve's
Have a spark tester at hand and check for spark immediately after it dies, or use a neon spark tester and observe if it is still flashing as the engine coasts to a stop upon failing.
Once you know whether or not it loses spark you can narrow your troubleshooting to either the ignition or fuel system.
If it loses spark the first thing I'd do is check for a mouse nest or other debris that is blocking cooling air movement around the coil (Briggs calls it an "armature") and through the cylinder cooling fins.
