Kohler K341
If your talking about the carburator main fuel float valve, the needle was plated steel with a rubber tip, the screw-in seat was CDA #360 free machining brass.
Thanks, I didn"t explain myself. I am wanting a steel needle instead of the rubber tipped.
Thanks for the reply. I see the Chinese Kohler Carb has a clip to pull the rubber tipped needle off the seat.
