Not exactly a lawn tractor but definitely small engine related. I repowered a 5 wheel JD Gator. 625 I think. It came with a 8hp Kawasaki horizontal shaft engine (apart and in a box). Small engine warehouse sells a kit that uses a Kawasaki FE250D-AS11-1 and a install kit. They had 2 kits on back order but said they would not even make the kits until they had enough orders to justify. They never said how many that was. So I got the FE250D-AS11-1 and went for it. The kit included a 1” offset mount (I moved the plate in the gator). It also included some linkage adaptors (manly to connect the Gators cables). I only had to change the choke cable connection, throttle hooked right up. They did have an air cleaner extender (engine moves to the left about an inch) but the factory cleaner fits just fine.
So I get it all in, put in a new fuel pump, all new lines, new filter, and clean out the tank (had been sitting for a couple years) and put in new gas. Spin it up and it runs great. That is until you give it throttle. Flat out dies just like starving for gas. However, if you have the choke out about ½ way it runs like a top. I see one adjustment on the carb but it only turns ¾ of a turn (#1 in the pic). Does not make any difference where it is. The clear tube (#2 in the pic) was not connected when the engine arrived. Left hanging open and the choke on it runs fine. Plugged off and the choke on it runs fine. If I plug it on the bottom of the carb (#3 in the pic) it does not run right period.
Anyone have any insight into;
1) What is or where does the clear tube go.
2) Why a new engine would require choke to run.
3) What if anything does / should #3 in the pic have anything connected to it.
4) One might find setup / adjustment information.
I plan to contact SEW but until I can get a response I thought I see if anyone here might know. In the picture I moved the valve cover vent tube to get the pic, it is hooked up correctly.
