Deere Mark
I have a Kohler engine K161T - 28127J and would like to fix the ignition part(s). The spark failed years ago and I have been using it with an external coil (from a Farmall Cub), and a 6 Volt battery, using the external points and condenser. Works fine that way, but I want to fix it properly if possible. I have been taking the engine apart and am ready to remove the flywheel. So a few questions before I really mess it up. How do I remove the flywheel? Am I going to find that the needed parts are no longer available?
Thanks in advance for any help.
