Wheel horse spitting and sputtering
My wheel horse raider 12 started spitting and sputtering like it was starving for fuel haven't had any problems with it until know carb rebuilt 2 years ago pulled the choke and it would run then die again then when I pushed the choke in it would run for about 10 seconds the spit and sputter again could it be my fuel pump?? Just don't know where to start.
Kohler, I did notice last night when I started it up it ran fine so I am wondering if it's the coil? I only ran it for maybe 2 minutes just to put it back in the barn.
(quoted from post at 09:06:26 09/13/20) Kohler, I did notice last night when I started it up it ran fine so I am wondering if it's the coil? I only ran it for maybe 2 minutes just to put it back in the barn.
First thing I'd do is clean or replace the sparkplug.
Seems premature to condemn the coil (but anything's possible)?
I would take it back out. At night in a dark place. Let it run and see if you see any sparks. Onan had this problem. Turned out to be a cracked coil. Really showed up in the dark.
