The parts list shows two different part numbers for the electric fuel pump for the F935 mower. Based on serial number (11247) am876116 is the one we need but there's very little to be found via Google. However, am876226 is all over the place. Can anyone tell me the difference between the two? I see where am876226 is listed with a black connector or a white connector. The white connector appears to be the same as the old pump on our mower. I am wondering if the pressure and flow rate is the same between the two pumps or if it's different. The old pump has JKC, 0212, and 2000 stamped on it but none of that info comes up in a search. I'm thinking that I can use the am876226 as long as I get the white connector, but I hate to assume and find out that there is a difference.
