I have Kohler K161 with a battery ignition and a starter generator. If I understand correct a starter generator has to have the solenoid on all time in order for the S/G to charge. The way I have it wired now the solenoid stops supplying current to S/G as soon as engine starts running and I release the key and it goes back to run position.
Here is what I have Starter switch Has 4 terminals, ACC, Bat, Ign, and start. Voltage regulator has F, B, Gen, and L. S/G has F, A. Any help wiring this will be appreciated.
