I am working on a John Deere 400 which has a peerless 2500 transaxle. Although it functions fine I have noticed end play in the axles and some slop in the drive. I assume some movement is expected from backlash in the gears so it is the end play I am most concerned with.
I took one of the axle supports off mainly to investigate but cant see much. I assume the movement comes from worn thrust washers on the axles/differential. I do have a couple of digital manuals, but they are not very detailed.
My main question is if or where parts for these are available? I can get bearings and seals locally and make a gasket if I have to, but if I go into this thing further can I even get parts? Im assuming some of those thrust washers and/or snap rings will need to be replaced. Lastly, does anyone have advice or experience with one of these units?
Thanks,
Lee
Thanks,
Lee
