Company Logo Shop Now
Re: Kohler K321 starter?
daisyman
08-08-2020 15:26:59
Heck no, you're good to go. Two drops of oil after 50 years of operation doesn't seem too bad, probably good for another 50. If it was worn, it wouldn't be squeaking, it would be rattling. You, might, however, want to do the same for the back bushing, but you'll have to loosen the bolts holding the starter together, and VERY gently slide the end plate off just far enough to get a couple drops it there. There's two styles of brush assys. One is on the o. d. of the commutator, and the other is pressed against the end of the commutator, and neither are much fun if you've never taken one apart before. You don't want all the springy things flying everywhere, so just take it apart enough to get your oil in there. Oh, and while you're in there, take a peek at the brushes to see how worn they are. They'll last a long time if the tractor is well taken care of, as it sounds like your's has been if you've had it since '72. The actual run time on a starter is very short on a good running, tuned up Kohler. My humble 2cents worth and that's about what it's worth.
Irv
Copyright © 1997-2020 Yesterday's Tractor Co.
