CenTex Farmall
I've got an older 5 hp briggs that I want to get going. It has the iron sleeve and the bore is in excellent shape. The piston is
fairly scratched up so I want to replace it.
The problem is that it does not have the original housing with the model number. What I do know is that it's a 130000 series with
an iron sleeve.
I've narrowed it down to two part numbers: 393819 and 298904
I'm not sure which one is for iron bore and which is for the aluminum bore or if they're both wrong for it. I've about worn Google
out and haven't found a definitive answer.
an iron sleeve.
