Bolens tiller
Have a rear mount shaft drive tiller 24"wide 6 spline drive shaft Red in color. What model tractors will this fit looks
like it was used very little thank you
The model and serial number would help someone who knows the Bolens line.
Pictures would help more.
Three point hitch?
Proprietary mounting setup?
Do you have the mounting parts?
Without a model number or pictures, it sounds like it’s from any of the tube frame models. I have 2 tillers that fit your description for my 1254 and 1050. Those models used the 6 spline pto shaft before bolens switched to higher spline count shaft on later and larger models.
