Company Logo Shop Now
Re: KOHLER FUEL PUMP
shinnery
07-28-2020 23:14:20
Here us one example of an electric pump, 3-6 psi, you may want less pressure than that.
https://www.amazon.com/Diesel-Inline-Pressure-Electric-Fuel/dp/B01FLW0NQM/ref=pd_day0_hl_107_10?_encoding=UTF8&pd_rd_i=B01FLW0NQM&pd_rd_r=f669b2e0-84b1-11e8-b99a-5517ba108a65&pd_rd_w=AuM5E&pd_rd_wg=9kHjq&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=4014010564823900592&pf_rd_r=WETZNVYTAY838XGHBT9Y&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=WETZNVYTAY838XGHBT9Y
Russ from MN
07-30-2020 06:47:15
 Re: KOHLER FUEL PUMP in reply to shinnery, 07-28-2020 23:14:20
I have thought about putting an electric pump like that on our Husqvarna with a Kawasaki. The fuel tank is lower than the engine, so after sitting for any extended time it has to crank awhile. I suppose they don't use them from the factory because of the safety concern, if it leaks it would keep on spraying until you shut the key off. Can you just hook a pump like that up to the ignition circuit? We have never had any problems with our lawn mowers so I'm not sure how the ignition works, because it works so well! Thanks!
fras
07-30-2020 04:11:48
Plastic fuel pumps don,t last , I take the fuel pump out , make a plate with fitting for 1/4 inch hose and use the briggs&stratton vacchm fuel,pump , works good , I did this a dozen engines , plus if the fuel pump goes bad itís easy to change mount it close to the carburator
fras
07-30-2020 04:23:37
 Re: KOHLER FUEL PUMP in reply to fras, 07-30-2020 04:11:48
Vacuum fuel pump costs less then 18.00 and works on motors up to 25 hp
Copyright © 1997-2020 Yesterday's Tractor Co.
