electronic point conversion
MoMac
Hello. I have a 60 something Speedex S14 with what I think is a B&S 5 horse. I would like to update the coil and maybe go to a pointless ignition. Is this possible on these older engines? Thanks, Mike.
yes, it can be done but you have to have the correct coil with either 2 or 3 legs of lamination's before getting the correct kit from B/S.
Pull start means nothing one thing you have to check is the flywheel magnet if the magnet is separated so it looks like 2 magnsts it will not work with the magnetron electronic coil, if thats the case find a flywheel with just a single magnet then your good to go
GB in MN
