Suddenly, the temp gauge on my JD 425 is running real hot and I suspect the thermostat. I looked online and I saw that John Deere went from a 160 degree stat to a 180 degree to comply with some EPA regulation apparently. Some guys say the 180 degree stat makes their tractor run poorly and some guys say they were told by Deere to change to a different carb to ameliorate the poor running issue. I called our local JD dealership and the old part number (AM109396) is now replaced by part number M123434 which indeed is 180 degree. He's never heard of anyone having to switch carbs after putting in the new stat. Does anyone have any information about this? Also, does anyone know if NAPA or any other aftermarket stat will replace the JD? I've heard Auto Zone part number 7203-160 will work but others report the AZ part does not have a taper and nobody that I saw actually said they used it successfully. Thanks for your help.
