International Cub Cadet Parts
Pipestem
I’ve got three Internationals Cub Cadets and need
some parts. Especially mower drive belts. Any
advice on the best place to find parts for these old
machines?
Pipestem; I have used “vbeltsupply” for belts on several different mowers and have not had a single issue . You might give them a try.
https://www.vbeltsupply.com/
Pipestem:
A good place is: [b:8b2bd5c973]https://www.ccspecialties.org/tractors.html[/b:8b2bd5c973][color=darkblue:8b2bd5c973][/color:8b2bd5c973]
Do a search for a company "Cub Cadet Specialties", they are the largest CC parts supplier in the US. Depending on which belt you need, probably the mule drive belt that runs from the engine, down to the idle pulleys and back to the top pulley on the center mower spindle, using non-OEM belts normally don't work well. I bought a Dayco brand belt at my local bearing supply shop for $7 instead of spending $30 at my local CC dealer. The Dayco belt lasted about 15 seconds, it flipped off the idlers and chewed itself completely up.
There's a website, IH Cub Cadet.com, you bring up the home page and there's five colorful boxes across your screen towards the top, CCS is 4th from the left, put your cursor on the box and tap enter. Charlie even has no longer available parts made and for sale. You can spend less for inferior parts, but you can't find better prices on GOOD parts.
Thanks for the information. I have had the same experience trying to use “auto parts store” type replacement belts. I will contact them.
Thanks for the contact information. A Kevlar belt might work but I have had problems trying to use other replacement belts. The don’t hold up very long.
The pitch angle and width of IH Cub Cadet sheaves isn’t the standard angle of something like a 4L or auto parts belt. That’s why they don’t work out real well. MTD still supplies some of the belts for the old IHs. Check partstree for the part numbers and search eBay for the best prices I’ve found lately. CC Specialties has most of them also.
