Club cadet 129 wont go
El Captain
New User
I have changed out the seals and gaskets on my 1973 cub cadet 129. Put back together and now it will not go forward or reverse. How would I go about purging or bleeding?
Which "seals and gaskets" did you replace?
Unit should be self-priming and self-bleeding..
Did you remove he "charge pump"?
If so, the little steel pin that drives it could have escaped.
Replaced the cork gasket between the hydrostatic and rear end. Also the gasket seal when you split the pump in half.
When running we took the Alan screw out where pressure gauge goes and fluid came out. Going to check out pin
When we put in forward or reverse we can hear hissing. Not sure if that would be air or the pump trying to engage.
