I have a Red Cub Cadet Hydro 382 that I?m trying to change the hydro fluid in and have run into some
problems. Already have the operators and service manuals and neither is clear on how to drain them so
I gave my local dealer a call. It was explained both the hydro and bottom end are conjoined and feed
HiTrans from the same reservoir so all l have to do is pull the plug on the very bottom of the housing and
both hydro and gear housing will drain through it.
All that?s come out is some gear oil, not old milky HiTrans which I can see in the reservoir, but thick fairly
clear oil and the reservoir is still full. Can anyone explain to me what I?m missing or have done wrong,
I?m pretty stuck right now.
