Troy Bilt GTX 14063 Snowblower Auger Shaft Grease?
Repaired the gearbox on the unit. Putting it back together.. The seals on the gearbox appear to seal to
the auger rail/hollow that goes over the drive shaft with the shear pins. There was a REALLY heavy
grease between the shaft and the auger rail.. That grease appears to hold the gear oil in the gear box
from running down the shaft. Anybody know what current grease to use for that 20 year old application?
