1984 Ford ST 526 Snowblower
LCUph
New User
My 1984 Ford ST 526 Snowblower Model 09GN5145 needs the impeller repaired and I cannot figure out how to remove the Platter Pulley from the end of the auger shaft so i can slide out the front auger to get to the impeller. Any help with this would be greatly appreciated. Thanks.
Not sure how the Ford is put together, but both the Toro and Deere I've worked on had 2 to 4 bolts that allowed the whole auger housing to separate from the drive frame. This allowed great access to the pulley for removal. You will have to disconnect the chute rotater. The set screw or bolt for the pulley is usually between the pulley and fan housing as it looks like on yours.
