Company Logo Shop Now
TractorLinks.com
Re: BS
momac
12-26-2019 06:51:15
Thanks guys. Found one in my tool box and figured out that it was nonferrous when the magnet wouldn't pick it up. Now I'm looking for a coil. One of the wires is broken off too close to splice.
old
12-26-2019 09:11:40
 Re: BS in reply to momac, 12-26-2019 06:51:15
Many time one can replace the old points type coil with a new electronic coil set up and do away with the points. BTDT a few times or I buy the electronic module that takes the place of points. I had one engine that the upper crank shaft bearing/seal was so bad it would not run as it should or long due to points not opening as they should and oil getting on them. Put a module on and worked well even though it smoked so bad you did not have to fog for skeeters. It was an engine on an old tiller I once had
Jeffcat
12-26-2019 16:01:16
 Re: BS in reply to old, 12-26-2019 09:11:40
Magnetron modules. They fixed more screwed up engines. Trouble is they only retrofit engines so far back. Lots of stuff from the mid 60s up. The small engines. I got to the point it was about 45 minutes to take the carb off the top of the tank, take a large fine tooth flat file and gently plain the matting surface of the tank and then preload and screw it together. The magnetron took a few more minutes. Ahhhh memories. Last of those i did was early 80s. Good gravey I just looked on Ebay and can't even find them anymore! All of the coils and ignitions are one piece. Here is the hardware store version they used to sell.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
