I have a older lgt ford tractor that has been cut down to a bare minimum( by previous owner/owner's) I have since built a buggy for my girls with it. Was told it ran a year before I bought it. Has sat for about 3 since I've owned it. Had a slight problem with the motor turning the pump the wrong way. Not the original motor, new motor was mounted backwards from original.
Well it's moved a time or to since I've been working on it not more than a ft of two, since my shop is small. Yesterday I pulled it out the shop and put the top on and backed it back in, move probaly 20 ft. It was jerky and hesitant to move. Then last night as I was driving it to the house it just quit moving. Hydro lever engages and it tries to move but it doesn't, jacked the rear end up, same thing. Changed the fluid, no change. Fluid is full, no filter on it ( how I got it).
I need suggestions on where to go now???????????
