Nextgentractorfriend
New User
Hello Friends! I just recently purchased a Case 220 mower with a 14 HP engine (a previous owner swapped out the original 10 HP with a 14 HP engine) that is from around 1982.
I am having an issue with the left hand side engagement lever, whenever I press it forward to engage, it barely if at all, moves the blades. When I force pull the lever towards me on the mower, the blades engage and I can cut grass (the second I let go, it stops the blades).
When I push forward, I can lock the lever in place by a click, but it does not move the blade belt pulley on the deck much or at all.
The first picture is when I push the lever forward and the second is when I pull it towards me.
Any advise or help would be greatly appreciated!
Thanks friends!
Thanks friends!
