d13series1
2014 Courage 2 cylinder. Runs great, got the leaking valve cover sealed up (hint - make a real gasket for it).
Start, mow, stop to move the drain spout. Turn key, starter whirrs, no motor action. Turn of, try again, catches and off we go. Stop in a bit to get gas. Turn key, starter whirrs, no motor spin. Move motor over by hand, repeat, same result. 12V to starter when engaged, so not battery. Since I can hear start spin, I'm thinking bendix (assuming it has one), or starter pinion stripped (is it keyed onto shaft?) or all the teeth missing, which I view as least likely since it worked then suddenly didn't. Other option would be stripped flywheel which also seems unlikely. No weird noises before, has worked fine up till now.
Any thoughts before I rip into it?
