Company Logo Shop Now
TractorLinks.com
Kohler K341 oil leak
Alkolano13
09-10-2019 16:53:15
Kohler k341 oil is leaking thru this hole on the drive side. What is the for and what do I do?
Alkolano13
09-10-2019 18:35:56
 Re: Kohler K341 oil leak in reply to Alkolano13, 09-10-2019 16:53:15
Thank you for your reply. Yes it is the top hole. Pic is rotated. What would have caused this? So it hard to pull flywheel off?
t.r.k.
09-11-2019 09:05:27
 Re: Kohler K341 oil leak in reply to Alkolano13, 09-10-2019 18:35:56
How long since it has been apart? If someone had it apart recently, they may not have gotten that shaft tight in the hole. like I said, that pin is a taper fit and you actually drive it in the hole with a hammer to tighten it up.
If its been years since it was apart corrosion or vibration may have caused it to open up somewhat. Keep in mind that all those engines are over 20 years old at least. Probably more like 30 or 40.
t.r.k.
09-10-2019 18:11:08
If its the top hole in the picture (The way its posted here, which is sideways) That is the end of the shaft the camshaft turns on. If it was me and it was not leaking at the other end behind the flywheel, I would clean the hole with Brake cleaner to get the oil off and fill it with RTV. Then let it sit for 24 hours before I ran it.
If its leaking at the other end, it is probably loose in the hole and you need to remove the flywheel and the cover plate and drive it back in. This is right much of a job in most cases. And of course you need a new gasket and probably a pto seal as they are easily damaged.
That pin drives through from the other side of the case and is machined slightly larger on the other end so it wedges in the hole. If you ever take it out for any reason you need to put sealer in the hole before you drive it in.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
