JD 317 lawn tractor
Kow Farmer
Does anyone know what the thread pitch is on a engine oil drain plug on an Onan engine? Not sure what model engine I have. I just acquired this lawn tractor recently. I want to replumb the oil drain to make oil changes easier in the future. Thank you.
Kow Farmer Kurt
If it's the P-218G Onan that was sold by DEERE as an upgrade to the original Kohler, jdparts.com shows the main drain plug to be 1/2-13 UNC, and sealed with a nylon washer.
(This is the drain plug screwed from the bottom up into the engine base. There's some pipe plugs in other locations in the engine base that are 3/8" NPT.)
