16 hp Briggs problem
I have a 16 hp Briggs on a craftsman rider. The engine starts and runs then acts like it?s going to die then smooths out. Then repeats. Any suggestions?
That sounds like its not getting enough fuel. Does feathering in the choke help it some? If it does, it probably needs the carburetor cleaned, fuel filter replaced, or some such.
(quoted from post at 23:12:41 07/12/19) Got it. Bypassed the fuel safety solenoid and adjusted the carb. Thanks.
How did you bypass the fuel solenoid??
The solenoid is opened to allow fuel to enter the main jet when power is supplied to it.
Cut the pkwer and it closes thus shutting off fuel flow.
