Kohler Float bowl
caterpillar guy
I need a float bowl for a Kohler engine on a Troybilt tiller The engine is a K161T I have 2 serial numbers not sure which is which. 2812711 297862
This is on a 7 horse Kohler on the older horse tiller. The bowl is 2-3/8 diameter and 1-1/4 deep with a rounded raised rib around the bottom and 5/16 hole on the bottom for the bolt to hold it on. A part number or a replacement would be great.
I do not have a p[art number but a few years back I had to replace the one on my Troy built and all I had to do was go to the local lawn mower repair place and they where able to order me one. My old one had rusted out and leaked
Yup went there and I had to give my first born right arm and a few other unmentionables for one. Why I am looking for an alternative route. I see them from 8.00 to 40.00 on line. That is why I was looking for a part number to make sure of the correct one.
Just sent you some pictures of mine. It is aluminum with the groove around the bottom. It should be from a dboonies email.
Kohler K161-281271 . 7 HP (5.2KW) .. . SPECS 2801-281298
Just google Kohler K161 carb.. You can find tons of new aftermrket carbs for less than $30 each.
