Diymechanicmike
Ok so i just got the engine in it for my tractor and put it on and i just installed a 1.75" pulley as the drive and it was going walking speed but once i turned back up my hill the clutch started slipping so i assume it needs tightend a bit as it took off on flat ground and down a slight hill but once i came back up it wasnt going. I soaked(pb blast) the edge of the pulley thing that the adjuster nut is inside of and took the set screw out of the hole over the flat spot and i assume i need to tighten it to wear the other hole is on a flat spot or maybe even more. But, whats the trick to turning just the outter disc inward on the adjusting thing?? And if anyone has better terminology on these parts, input please lol i hate saying do-hicky here. Lol
Thanks mike
Thanks mike
