David Bradley walk behind tractor
Branseal87
New User
I am looking for a set of wheels for my David Bradley graden tractor are what other what other wheels will fit these the original wheels has 3 hole for the lug studs
This has been brought up on here before, might be able to find it in an archive search.
I remember suggesting that they might have the same pattern as some older 5-hole car rims, just ignore two of the holes.
Someone else chimed in with more information, or a correction to my idea, but I've forgotten the details.
A quick GOOGLE search turned up the following: "All David Bradley walk behind tractors (2 wheel) use a 3 bolt pattern that is the same as a 5 bolt wheel with a 5-1/2" bolt circle. Ford wheels with that bolt pattern that fit are 1932 and up model A and coupe (hotrodders favorites) and then half ton ford pickups up through the 1960s I believe. So any wheel with a 5 on 5-1/2" lug pattern AND at least a 4" center hole will fit the David Bradley walk behinds."
HTH!
(quoted from post at 01:01:40 06/10/19) This has been brought up on here before, might be able to find it in an archive search.
HTH!
I think I have two of those ford wheels out behind the barn.
