kubota belt
bdunegan
I have a Kubota model # T1870A, serial# 20022 riding mower. It needs a transmission drive belt. The one that is on it has chunks gone out of it and it is so worn that I cant find any numbers on it, Does anyone know what length belt this would be by chance? Kubota has all their parts diagrams locked down and I really don't want to spend $125 for a belt. This is the belt from the engine pulley back to the transmission. Any ideas anyone?
If you have enough good belt use that to fill the sheaves and then pull a tape measure around the belt run. This will be your outside measurement, look online and order a belt, there are charts that will give you the number of the belt, unless it's an odball.
