Call out to MuleMeat
dzc3
I added a ground wire to rectifier, the ammeter shows it was charging about 2 amps with PTO engaged, maybe just a shade more with it not engaged. I mowed for about 1 hour, everything seemed to work as it should. Started to mow again, not charging. Put the voltmeter on to double check, that it was not charging. Shut mower off, put voltmeter away, started mower up and it charged while I mowed another hour. Shut mower off now not charging again. Any ideas what I should do next?
