John Deere 212
JonnF3
New User
So I have a John Deere 212 with a Koehler K301. I wasn?t getting any spark so I changed the coil and condenser. I also confirmed I had 12v at the positive side of the coil and continuity at the points (set to .20 gap). Now I have spark, but only after I let the key return from the start position to the run position. It will start and run fine after I release it to run but won?t start while cranking in the start position. Does this point to a bad key switch?
Yes!
Either it's failed, or someone has installed the wrong switch, or possibility mucked up the connections in the multiterminal connector that plugs onto the switch.
(quoted from post at 07:39:23 05/14/19) Thank you. Now to figure out which switch I need.
Part #AM103286, less than $15 at yout John Deere dealer, or on eby or Amazon.
